If you have any 1 inch ID grey pipe insulation (Home Depot).Put it on your suction line and use zip ties about every 4 in. or so and you should get 10 or more degs out of the vents.I did it and got 12 more degs. without icing up the evap.
I was thinking about doing this, but what about corrosion of the lines and joins?
If your thinking about the condensation, it won't happen on an insulated line. The cold line (the low side) stays cold and is no longer effected by the hot air surrounding it.
Look at you home AC unit, the cold line is insulated. Mine is wrapped with 1-inch foam insulation and then taped with aluminum tape.
I did the same thing to my Yaris. First 1-inch foam insulation and then aluminum tape. I noticed a huge improvement at idle (stop lights) and low speed. Highway speed seems to be the same.
That looks similar (foam instead of felt?)
Should work fine.
P.S., I fixed your link, you had a double-http// in there.
