- Oct 25, 2008
- Age
- 37
- rhode island
like the title say i pick up a 88 bronco 2 weeks ago . its got a 3 inch bl 4 inch suspension its got the a4ld and a dana 28 and the 7.5 . plans are to pull the bl and install the polly cab mounts i have cut the fenders and run 35s. im gonna swap a dana 35 and ex 8.8 with disc and 5.13s. the only problem i have with it is the preveouse owner rhino lined the whole thing so for the past 2 days ive been scrapping it off with a razor blade:banghead:
heres the only pic i have right now this is the first day home with it
i havent done to much but id figure i show how it currently looks ive got most of the bedliner off the drivers side quarter with a razor blade it not to bad cause the person who did it didnt prep it that well, plus i dont have to do the nose cause i have a ranger as a parts rig ive already pulled the nose off. plan with the fenders is to cut them and put them on when i swap in the poly bushings and pull the body lift.
got my spare fenders cut and the drivers side mounted i still need to trim the inner fender but i had to got to work. i also got a set of mustang buckets for free and threw them in but havn't got a pic yet. also may have a lead on a dana 44 and 9inch for a 100$ but i want to see what gears they have first.
picked up a double cardan drive shaft and newer style trans cross member for free to replace my worn out drive shaft and low hanging cross member also grabed a pic of the mustang seats.
drive shaft and cross member
new seats
new seats
