- Dec 1, 2009
Hi guys,
So I'll try to make this as concise as possible. I've done some research as to what kits are what, plate vs. replacement brackets etc.... Basically I'm sneaking this post in at work as I was hoping to get some suggestions/constructive opinions from some people who may have more experience with the Ranger than I do.
So here it goes, I've got a 97 4.0L Ext. Cab 4wd in pretty good shape inside and out, not a beater. At the moment this is my daily driver and I'd like to keep it looking halfway decent so I won't be out doing any hardcore off roading where I'd be taking body damage etc...
Basically I'd be fine with being able to go on mountain trails/mud/snow/ruts etc... basically moderate to mildly advanced stuff but not major rock crawling, squeezing through spaces where both sides of the truck are scraping etc... I know there is a place for all that but I have a dirtbike when I want to go hammer on stuff
I'd also like the truck to have a semi aggressive look and run a reasonably aggressive 15" wheel with 33" or 35" tire (if 35" wouldn't have a problem adding a body lift if needed), re-gearing could be a possibility but I'll decide that once I drive it and see how it feels.
Long story short, if hardcore crawling and expert stuff was a 10 on the scale, I'd like to be able to do a 6 or 7. The truck will see 90% street driving so I just want something I can have fun with and be able to hang with mildly modded other 4wd's on the trails.
This is where I need help, since this is my first time around purchasing a lift kit I've been considering these options.
1. Skyjacker 6" Standard kit (from what I've read I need the 6" springs to get a 4.5" lift on my 4.0 Ext Cab) with blocks or replacement leafs (comments on which if this is the way you recommend going)
2. Tuff Country 4" Extended Radius Arm Full Kit and swap the 4" springs out for 6" Skyjacker Springs (again, blocks or leaf in rear)
3. Skyjacker 6" Extended Radius Arm kit with blocks (Don't want to spend that much for a kit with leaves)
4. Tuff Country 4" Standard kit (non extended radius arm) with 6" Skyjacker Springs (blocks or leafs)
Note: If I did one of the "standard" kits I would be able to do F250 shock mounts if that would help to get me to a "middle ground" area between just a standard kit and an extended radius arm kit, not sure if the shocks are the limiting factor on the standard kit however...
I've been doing lots of reading and will keep on going with it but would like some input from experienced members as well as if I'm just going completely overboard with doing an extended radius arm kit for what I want then I could use the money for other things. Thanks guys!
