Just Plain Stupied
finally changed the driver's side caliper-retaining pins & anti-rattle clip!
I should have changed em 15 headaches ago............
:buttkick: (I am on the left side/Prozak is on the right side)
annnnnnnnnnnd another thang....I know can remove the 4 barel in less than 5 minutes!
as soon as i can afford a phone with more than 30 seconds of memory...i'll post a vid.
Well....I have the h.p. I need with the V8...now i need the elusive gas mileage.
Here's the 600cfm Holley 4 barrel...
Just Plain  Stupied
I removed the electric choke & the vacum switch from the secondarys/and disassembled the carb.....
Just Plain  Stupied
The FedEx guy just showed up with my new gaskets, carb bracket, book...
Just Plain  Stupied
just in time......
Just Plain  Stupied
the secondary metering plate main jet holes get plugged with siver solder and drilled to a smaller size.....
Just Plain  Stupied
Just Plain  Stupied
the modified plate gets reinstalled......
Just Plain  Stupied
the primary jets got soldered shut & redrilled to a smaller size also...
Just Plain  Stupied
The butterflys get a .060 hole in each one to lean out the idle--it always idles so rich that it puffed smoke rings....
Just Plain  Stupied
I connected the secondarys to the accelerator arm using the original linkage since they're not vacuum operated any more (yeah....I know I wasn't supposed to do that mod).....
Just Plain  Stupied
There....I sawed off the air horn & the choke plate for a streamlined look or better air flow now that I'll be using all four barrels at the same time (yeah--I know you're not supposed to do that).......
Just Plain  Stupied
I used a vacuum gauge to reset the carb after I bolted it back on...the truck runs like a scalded hyenna now (like they said--there's a slight bog if its floored...but I don't need to floor it with all 4 barrels working together!)
Now to go fill it up and check the gas mileage......
ATTENTION: I DISCOVERED THAT I DRILLED THE HOLES IN THE PRIMARY BUTTERFLYS 180* FROM WHERE THEY SHOULD BE LOCATED/BUT I DID DRILL EM RIGHT IN THE SECONDARYS! HENCE: JUST PLAIN STUPIeD!
.................IN POST 3441, I CORRECTED THE MED INDUCED DAMGE....ERRRR.....DAMAGE.
DEFINATELY need to install an O2 sensor and dash gauge to fine-tune all 4 jets NOW................
woah! you have 4 jets!!! you'd put this guy to shame then!
Just Plain  Stupied
Just Plain  Stupied
there 4.0B2 ................. i found yore piture....
Slowly but surely...
Like a dog with a shock collar. :yahoo:
Waaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaaahhahahhahaaaaaaaaaaaa.....I needed that.....Waaaaaaaaaaahahahhaaaaaaaa....weeeeze!
Which reminds me of a war st......no...wait....civilians story....
(get set--it's purdy good)
My youngest daughter (now growed up) just decided to get a traing collar for her dog....errr....training shock collar. Well(P)...she wanted to make sure the collar wouldn't hurt the dog too much (yes---she DID)...so she puts the collar on her next and yaps.....nothing happened
so she yaps a little louder.......
ZAP!
so then she screams from the unexpected zap.....
ZAP AGAIN!
so...........by the 3rd................
ZAP!
she manages to get the collar off and slings it across the room....
(yes.....she'a a chemically-induced blonde.....no she doesn't drink or do drugs....no she was not in Nam)
OHHHHHHHHHHHHHHHHHHHHHHHHHHHHH......i have a piture of her somewhere.....let me find it
be back in a couple......................
OOOOOOOOOOOOOOOOOOOOOOps.....wrong pic......
