- Apr 20, 2008
- Age
- 36
I have the basic idea of what you want to do but, I still have no idea what is going on inside your head! LOL!!!
honestly, i dont think ya want to
meh, im thinkin of makin somethin similar to a cyclone, or typhoon, except with lockin hubs and selectable 4wd.....i think it can be done....lol....now just to find the perfect donor truck
ah, those were gay. how bout the adrenilin (before actual production, when it had like 500hp)
im thinkin more along the lines of a small block, a cowl hood and a completely custom crossmember, i id have to figure out what todo with raising the motor, when i dot aht the trans is going ot be raised aswell, and there isnt exactly much room todo that unless u expand the trans tunnel and make a hum for the t-case to sit in on the floor
u wouldnt need to, just convert the 2wd, find a used set of dream beams(someones sellin a set on here) put a exploder 8.8 in the back w/ a 2" block and u got a bII on its nuts, also, put 4.10's in the 8.8, and a m50d is a must. it should mke for a pretty damn quick littl truck, if i were u id also do a chop top liek the one guy did on here and put ranger bed caps on it so it looks like a really shortbed ranger, and it would also lower oyur COG which means better handling, and that top section weights a ton
