- Aug 7, 2007
- Michigan
- My credo
- If you're not making mistakes, you're not learning.
The good news is that the Cesium 137 is readily absorbed by ocean water. It'll still be radioactive for the next 60 years, but within a few years it will be diluted so much that a day in the sun is no worse.
Remember, sun burn is radiation burn. I don't think any of that stuff is radioactive enough to give you problems.
3 Mile Island in Pennsylvania melted down. A study of cows milk from local farms a few years later revealed the milk was radioactive! OH NO! But wait, nearly everything is radioactive to some extent, and once compared to other foods, the cows milk was found to be less radioactive than a common banana. Yes, banana's are radioactive, one of the more radioactive foods actually. Supposedly you'll set off radiation detectors at airports if you carry one through.
Edit: Actually there's a movement for the "banana standard" of radiation. Basically to put to degree of scale of just how much / how dangerous an amount of radiation is so us common, low-browed folk can understand it.
http://en.wikipedia.org/wiki/Banana_equivalent_dose
time to tell work to go away,and get the dogs out for a good relaxing day
