I ran across another scale. 4500lbs on the nose with a full tank (gas station less than a block away) and full tool box. Driver inside.
I solved the tire balance issues I was having with new wheels and tires (yeah, they were wobbling after I got them balance the first time). Since they didn't smooth out after being 'balanced', I put some thought to it.
Without going in depth, think about what happens when you apply a balance weight to the wheel - but that balance weight isn't in the same plane as the center of mass of the tire/wheel assembly. It creates a pure moment that will try and turn your steering wheel if installed on the front.
Static balance isn't enough. Tires MUST be dynamically balanced to counteract the moment I just described.
I did a sample calculation using a 50lb tire/wheel assy with its center of mass having a radial eccentricity of .125" located in a plane that is 1" forward of the wheel mounting surface. For my conditions, it took 11.75oz to statically balance it, but ANOTHER 28+oz to dynamically balance it.
If you're having tire wobble troubles, do some serious research on dynamic balancing. Some tire techs know what it is and how to do it, others are clueless. I haven't found one yet that truly understands what they're doing. They just do what the machine tells them to.
Anyways, I got it figured out. It took 2hrs of spinning tires on their machine, but the truck rides like a Caddy again.
Makin progress on the sliders. Still need to skin them and build the supports running to the frame. Picking up material for the supports tomorrow after work.
old vs new. Slightly wider main wing with a 2.5" kicker.
