- Mar 15, 2012
- California
has anybody bought the chip that is advertised on here? 75 more hp and 3-8 better mpg? any thoughts or advice on it??
I like jalapeno chips........
Really? Most vendors are at least modest about their lies, they'll claim 20 or 25 HP not 75 that's nitrous, and forced induction numbers...lol
Those chips usually just fool your vehicle into thinking it's starved for fuel, causing it to dump more and running it rich, in theory if the engine clips get more air then yes it would help. But as it stands without forced induction of some kind then it's just running rich...not good and def doesn't help mpg. Nitrous at least gives it a colder charge thus allowing more fuel and better combustion. This chip just ruins your engine.
Your better off with one of those hokey electric turbos rofl...:screwy:
You speculate too much, most of your points are wrong... I will elaborate when I am not on my phone
Sent from somewhere naughty!
But as it stands without forced induction of some kind then it's just running rich... not good and def doesn't help mpg.
put simply, your theories are incorrect, but your conclusions are accurate
agreed
nope, this would cause it to run worse, and would NOT net gains of power... the only way to make the engine make more power is to get more air(read oxygen) in, or make it more efficient, typically through stoichiometric efficiency, which essentially means you are providing the combustion chamber with the perfect air to fuel ratio, which is 14.7:1 for pure octane (a main ingredient in gasoline) where as gasoline's perfect (read most powerful) is a little lower in the air aspect, closer to 13:1... which essentially means that for every 1 part of fuel, there is 13 parts air... any variation from that ratio means that there is something in the combustion chamber that is not burning completely... this decreases efficiency and power... the next thing you can modify with the chip is spark advance, cam advance (depending on the motor) and a few other variables
nope...
no! nitrous oxide, which is N2O, is an oxidizing gas, yes it is a compressed gas, which is a liquid, and when it decompresses and becomes a gas, the change of state cools the charge, but the big factor is how it oxidizes, so in a combustion chamber, it acts similarly to pure oxygen... because it's the oxygen that's in the air that causes the combustion with the fuel, the more oxygen you add, the more fuel you can add... it's essentially the same as forced induction, because when it burns, it is the same as if you have forced more air into the cylinder, but without the added resistance on the compression stroke...
ehhhhh.... i doubt it
