I like your parts chart. We are getting mostly the same parts. It looks like you are planning to get the inserts for the knuckles that you just drill out and press in for over the knuckle steering right?Do you know if those will work on the pitman arm also?
And have you talked to duff about using their trac bar mount? Also I wasn't sure a 15'' wheel would fit over the calipers on a d44, maybe I read something wrong somewhere?
I will be reaming the pitman arm, I have an Xcut reamer and possible the knuckles too. If I have to run a 16" wheel I will but my father runs 15's on his ford outer 44 with no clearance issues with his calipers. Will duffs bracket work on a ranger?
Pitman arm is a no go for those inserts...not enough meat on the arm and the inserts are too tall to fit properly. Pitman arm needs to be reamed to accept larger TRE's.
^Correct if I run inserts they will be on the knuckles only.
