- Jan 17, 2008
- Age
- 56
hello all, looking for help with a leak. my 94 ranger with automatic trans has a bad leak. I power washed it to find it. on the passenger side right above the pan on the side of the trans on the front part of it are two round things with caps on them held in by circlips I think. they are about 1.5 inches in diameter and in front of the vacuum diaphragm. they look sorta like freeze plugs. one of them has popped out of its seated position and is still stuck in about halfway. thus causing a bad leak. I think I can get it out. the truck drives fine as long as i top it up with fluid. it leaks like heck when it starts up for about 10 minutes then it stops leaking after it's warmed up and topped up. what causes this? maybe just a bad circlip? or is this an indication of something worse? this does not appear to be a moving part or a wear item. any ideas? should I just pull it
and replace it?
dude,he's working on a transmission, not a motor
