Nor Cal chat thread
forecast is calling for rain and snow all weekend in truckee, so I am gonna go with things are gonna be a bit sketchy. you game to play it by year?
Miller, weren't you looking around for an 8.8 4.10 axle? I have one laying around now, may need some bearings though.
i just found a better one.. lol. its one in eureka, yukon 4.11 gears, detriot locker, and its an expo axle so 31 spline shafts and disk brakes. all the fab work is done, its already set up for a ranger. thanks though. if it doesnt work out ill let you know.
How much? That thing sounds like it is setup...
300. im gonna check it out really well. what should i look for?
Make sure everything rotates smoothly, axle shafts don't have excessive in and out movement (a slight amount is normal) and NO up down left or right movement, grooved/warp rotors, excessive backlash between ring & pinion, straight housing, and perches welded on at the same angle.
If it all (hell if most of it checks out) $300 is a steal. The housing and gears are worth that alone.
I'd pull the cover off and make sure it has a detroit and said gears in it.
^This
FYI in case you didn't know, count the ring gear teeth and divide that by the number of pinion teeth...that will give you the ratio :icon_thumby:
awesome thanks guys. idk if hes a member here, but hes on RF. t5cents is whos hooking me up with this, its his neighbors axle. we're planning on taking the cover off and doing a fluid change before it goes in.
yeah dont give him money until you know its got a detroit and the gear ratio.
here is the proof.
my new exaust came in tonight. im hopefully going to weld it up tomorrow.
i just creamed my pants dude. cant wait to see it in person sometime this summer.
make sure to get hella pics and vids next time you guys go play in the snow lol
