- May 13, 2009
- Age
- 35
- lisle ontario
should hold up. only thing is it may drop a bit when you open it but i doubt it
No, it won't work, you need to move it to the right, or when you try to open the hatch, it will hit the tire carrier.
from the looks of the one picture of where you have the bar laying on the bumper it won't work.
Robert
I took my tire rack off too. I need to fill my holes. Looks good
is it dropping in the bushing or is the whole bolt moving? thats what i mean about the double shear put a plate by the head of the bolt and then back down to the bumper thatll stop it from pulling on the bolt
I still think your going to have clearance problems with the tailgate once the tire hoop is welded on, that or your going to have to open the carrier past 90 degrees.
is the tire carrier part sleeved ?? if not, I would sleeve it or the edges will dig into the bushings.
Robert
