Hey fellas, so I have an 86 bii.. I've just put in a fuel inected 302 out of a crown Vic with a 5 speed M5od out of an f150 as most of you can imagine my rear axle lasted about a month with this set up..
then in search for something stronger I stumbled onto a rear 8.8 axle out of an explorer with 4.11 gears for a $150.00 not bad so I grabbed it.. However now I can't use forwheel drive cuz I still have the stock front end
... This is where I need help.. My question is, what straight axle can I put up front that will work with my 8.8 with 4.11 gears or do I need to buy a set of gears and throw them in a different axle? Would it be cheaper to just find a set of matching axles? I'm hearing alot about ford 9inchs and te Dana 44.. I'd like to get by without putting my girlfriend on the streets for money but will do what I have to for the broncosuarus
I appreciate any replys and trust me I've been through the site and I'm just a bit simple minded so I sometimes need to hear it direct from someone ha ha thanks guys!
