- Jan 5, 2009
- owensboro, KY
Cleared it out, tapatalk doesn't tell me when it's full.
Dude, wtf? I drug around 10k lb skid steers on trailers, diesel front mount mowers and other trucks on car haulers, and full yards of gravel in the bed when I was on 35's.... Never shelled a tranny!
The bad luck has to run out soon.....
Yes you can, however this Transmission Case was questionable when we put it back together as there were a few spots where the races had spun and ate the case up. Enough to raise an eybrow, but not enough to not justify reusing the case. At this point, I don't trust this case at all (or main shafts for that matter).i wonder if you can slip the guts from a m50dhd in to a m50d?
man that tranny looks good!!! lol
That's good to hear. I did a lot of internet looking last night and there are very few failures for these transmissions other than running them without fluid. If I get the gumption later, I'll pull the tail housing off and take a look at things back there to see something else had gone wrong.Something is up, I dumped the clutch in my ranger in 1st through 3rd so many times it wasn't funny. Speed shifting,no clutch while shifting just plain abuse and the only problem I ever had was loose shifter bushings.
I don't think the failure was the tranny's fault.
... making more play and causing less and less if the teeth to make contact...
There is a guy selling a np435/205 combo with the 4.0 adapter in the classifieds...
