- Jun 6, 2009
Well had an hour to tinker with the compressor tonight. The drain valve on the bottom of the tank snapped off during the move, i.e. the coupler in the bottom of the tank snapped in half. Had to finesse that out of there and cleaned up the threads. Piped in a new drain valve, and temporarily wired the compressor to the panel. Flipped the switch and it purrs like a kitten, its actually amazing how quiet it is. Built pressure to 150 psi in hardly no time at all, and there were no major leaks (other than a tiny leak from the solenoid air line). The compressor itself is MASSIVE and is a two stage pump, rated at 300 psi, so it hardly has to work to fill that tank at 150.
Pic for reference of size
and proof it works
hope to have it mounted and bolted down in its permanent location, wired permanently, oil changed, and filter/regulator/hose reel hooked up this weekend.
and proof it works
