- Apr 20, 2011
so lets say i wanted a 2 inch body lift how much would it cost (about) to get spacers for however many mounts my truck has...
I just don't like the look of body lifts, nothing lines up right afterwards. The motor is to low in the hood, the frame shows more, bumpers don't line up, steering issues... so on.
All of my body lifts have looked great. I have always used PA gab guards and they are the best. I never ever had any steering problems or body alignment problems with any truck I have done. Everything aligned perfectly. I will only use a PA bl. I do love the way you can move the bumber up with the bracket kits as well. Nothing wrong with a bl. It is always so easy to change out the plug wires and remove spark plugs as well....lol
see, problem is... even the PA bl's don't include bumper lifts for an 88.
not everyone is doing body lifts on newer vehicles.think about it..
and by the time you pay for the PA body lift (about 150-200?) and the gap guards (run about 100?) you're most the way to a 4" RC lift... or you could do some smart buying of used parts and have a complete 4" lift a lot better than the RC![]()
you dont need bumper brackets for the older style, its even easier, just put your lower bumper bolts on the upper frame holes and use some metal to brace it, i'll load pics of what i did, i'm pretty sure my 94 has the same mount design and the older gens
well maybe it does a little,since he wants more than a 1" lift.
I have done this also with an earlier Ranger. I had plenty of scrap metal laying around our shop and had to do some fabricating like you did. I think yous came out better then my older 86 Ranger...lol. My 89 BII had a 3 inch PA lift and I got the bumber brackets with it when I ordered the kit. I moved the bumpers up. PA did not have the rear bracket kit for my 83 4x4 Ranger and I just left the rear alone. The front came with brackets as I raised up the front bumber. I never even thought about calling PA about the reason they did not have rear brackets and they had front brackets at that time. That was back in 84 when I did the suspension and bl on my 83.
And Kevin, you are right about how easy it is to do this. I saw your photos below and the bracket fab came out great!!
