You know you drive a bronco II when
When your 2.9 cracks a head, your TFI craps out, and your D28 snaps a shaft. All in the same week.
you know you drive a b2 if your valve cover gaskets leak onto your exhaust manifolds
You know you drive a bronco II when your awesome.
When you buy one for $150, haul it home and part it out to other bronco II enthusiasts! Only thing that was salvagable was the transmission and body parts. Oh, and the dirty thong I found under the seat....
salvaged thong eh? no comment...
you know you drive a bronco ii when you break one those large back windows and your trying to replace it.
this thread is great:headbang:
You know you drive a Bronco II when you drive a Bronco II.
Hey, someone had to say it.
When you pull into the local ORV park, and the "Heepers" ask if your going onthe trail with "that"? Then you pass them later on the trail, while they are stuck:3gears:
you know your driving a Bronco 2 when you are going up a 3% grade, throttle floored, and you look at your speedometer and your doing 35mph. :shok:
you're doing it wrong....
