- Dec 14, 2011
I know this isn't the forum for the earler Ford Courier, but the elements are similar to the Ranger.
My largest gripe about living in California is dealing with the smog nazis. The 2.3T build has always appealed to me and have some real fun with it, I have to get around the sniffer. The only real way I've seen to do this is to source the '72-'75 Courier and do a transplant.
This comes with a problem however. The earlier 72-76 Mazda 1.8 engine motor mount supports are significantly different then the later 2.3 OHC mounts used in the 77-82 trucks. To combat this, I have thought of simply changing the body from the frame on one of each type. This will give me the 2.3 OHC mount brackets.
Is the VIN for each meant to classify the frame or the body as the actual truck? If it's the frame, can I still get around this?
