body lift
hagdog
10+ Year Member
i am thinking about a 3'' body lift for my 98 ranger p/u. the kits say they come with all hardware but what problems will i encounter, such as fuel tank filler neck, fan shroud, shocks, steering linkage other? any advice or tips from anyone who has installed one of these kits wold be very helpfull. thanks!
Do you have an automatic or a manual trans? If you have a manual, you might need an extension for the shifter.
hick
filler neck might need extended,fan shroud needs moved or trimmed,shocks need nothing as you are just raising the body not the frame,steering extension needs to be used or the steering will bind a little. they are not to hard to install just watch the wiring as you lift the cab.you also have to move the parking brake cable up higher on the frame.if you have a manual truck you might need a shifter extension and trim the floor.
if u have a manual truck you will need a shifter exetion but everything else comes with the kit watch all ur lines when lifting i did not need to exend my fuel lines on my 99. have fun :icon_welder:
