- Jun 8, 2008
I know when this truck was built they built it for a speed limit of 55 mph, thats why the speedo is marked with red @ 55. So since I drive closer to 70 - 75 mph should I re gear the rear end? When I am doing 55 my tach is at 2000 rpm's and I would like it to be at 2000 rpm's doing 70.
My question is has anyone ever re geared a stock 4.0 OHV that was built about the same time as mine and designed primarily for 55 mph on the highway? Meaning you have a red mark at the 55 on your speedo and are turning about 2000 rpm's @ 55 mph. If so how did it go and what were your mileage improvements. I am debating re gearing but want to make sure it is worth it. My truck is a 94 extra cab with a 4.0 OHV and I am currently getting about 14.5 mpg. Motor and trans have been replaced and truck is stock except for the Delta cams rods and rocker arm assembly. newer 4 hole injectors and a cold air intake.
I also have no idea what transmission I have I know it has an overdrive but would like to know what it came with. I also dont know what rear end it came with either or the gearing but if anyone has the answers I would appreciate it? I am currently stuck at work and had time for a quick post so I thought I would ask. Once I get some time to get with the truck or use the search function I will figure the rear and trans out.
Thanks
Thanks
