kimcrwbr1
The fluid is fine, I flushed it about a month ago.
Think the mechanism itself is just poopered, so.... 'nother hundred bucks into the beast....
uggh..
All the best,
Hooper
Have you tried pulling a vacuum on the reservor, get a spare power steering pump cap and fit a nipple on the cap then rig a jar with two nipples on it to catch any oil it may pull then run a vac line from the pump to the jar then from the jar to manifold vacuum. Put the jar somewhere safe and just drive it around like that and check the fluid regularly working the steering from stop to stop it just may quiet the pump/gear down some.
