- Nov 9, 2011
Good Evening everyone,
After many days of over thinking my budget and the time I have, I decided that I would buy myself a Ford Ranger. As for the exact sub-model, I do not know yet but I am looking for a 4.0L or even a 4.10L.
Now that my car make and model has and will be chosen, the decisions of which tires and how much lifting I want comes into play. Keep in mind that this Ford Ranger will be used for work, such as transporting doors, windows and other materials such as wood and metal, without going overboard, it will also be used as a leisure truck and I will be using it to go in trails and might also go mudding from time to time. I do understand that it will put a heavy load on the truck, frame and other parts of it as well.
The first question is: taking in mind the activities that I will be perfoming with this truck, how big should the tires be? I know this seems more of a personal question, but the bigger the tires, the more gas and mileage it consumes, the pricier it gets especially if you need to change the differencial. I was looking at a good 33'' tires give a nice look to the Ranger.
My second question is directly related to the differencial change: How big can the tires be without having to change those parts of the truck? Honestly, if it would make sense, I would buy the 37x13.50R-15LT, M16 Tire Super Swampers but I know that it will inquire me to not only put a lot of lifting and change the differencials on the trucks axels.
My last question involves lifting: How and where should I lift? I understand this is once again a more personal question to be answered, but is there any negative effects or positive effects of only lifting the frame of the truck or the cab of both? Should I lift both or only one? Should the rear axel be lifted higher then the front or vice-versa?
Thank you for your kind help and generosity. I will be posting pictures once this beauty is finished and tamed and ready to ride!
Goodnight!
Goodnight!
