- Nov 2, 2011
I was woundering if someone could help me. I have an 01 Ranger edge 2x4 and I want to put a diesel in it! Does anyone have any advice or have done this before?
It think it was a joint venture between Komatsu and Cummins to develop it. It's an ok little engine. It was never intended as a vehicle engine but several people have decided it's good application for it. Some of those guys on that thread are getting upper 30s for mpg in smaller vehicles, iirc.
I was trying to go for the more practical diesel swaps, ones you can actually street drive and pound out miles on.
ANY of the 4 cylinder "4BT" style engine class is going to run you at the least 800lbs (dry weight) of just engine. Not adding in the bigger trans, and everything else. This needs to be considered.
Strap another 4-500 lbs of sand to the hood of your Ranger and you'll have a good idea on how it drives.
Snoranger is apparently daring to try it, and I am curious as to how it'll work out in the end.
Just saying if you go for a diesel other than one out of a car, you'll likely be needing to help out the front suspension.
