ill give you guys some insight on parts and fitment
starting out i stripped the complete front down. installed a durasolid full spool with 4.10's.
machined and tapped the right knuckle for high steer arm for drag link. the stock drag link tie-rod end has too small of a tapper because the steering arms are designed for gm tie-rod ends, but what i did was go to autozone and picked up a tie-rod end for a 85 bronco part # es2026r which had the same thead as the stock ranger tie-rod sleeve so all i had to do is thread it in. the thing was the bronco tie rod is a little longer which i also stayed with full width, so if your going to go with a shortened d44 this may not be the best option.
mounting i went with bronco or f150 radius arms wedges and radius arm mounts.
spring's i went with the deaver superflex 4.5 springs since there a little stiffer and i used the f250 blocks in the rear and already had a whole set of explorer leafs except the long one added to my stock leaf with a 2" add a leaf.
spring mounting i wont go into because there is too many choices of after market coil buckets and axle spring plates.
i decided to build my own track bar. got some track bar brackets, rod ends, and tubing from ballistics. ill have a picture of the modified track bar frame mount.
for some reason my front drive shaft was still good length. when i recieved this axle. the drive shaft was cut in half with the axle end of it still attacked to the axle. i thought i would do a little tinkering and what i found out. the slip joint from the 76 f250 driveshaft was exactly the same as my stock ranger one. so to get the right u-joint size all i had to do is remove the boots. and slip the half of the f250 driveshaft right into my stock driveshaft.
im done writing for now, and have a little writers block. ill be back with more information, and feel free to ask question i havent gone over yet.
