one of the few on this board?
same thing. is the cps working ?? valves moving cam spinning?
chains break, gear bolts shear etc....
Oops I didn't see Bobby's reply here. Sorry Bobby!
if its a roller cam you need a bronze gear on the synchCheck your cam synchronizer. Just wondering... the cam you put in it - is it a roller cam? I don't recall what the gear on the cam synchronizer. Hopefully steel.
Dan,
you are forgeting Hoosier1104 is running the Explorer motor and I think a couple more. Get them videos of Bryon?
Dave of the Nord
Steel or composite gears are recommended on hydraulic roller cams. Steel gears are factory on the HO 5.0 Mustang.
EDIT: Mostly you don't want cast iron.
Comp cams tells me to run a bronze or composite gear on a roller cam, i have personally installed hundreds of them and none have worn badly (95% are in racing applications)![]()
The Syncro Spindle has less than 10K miles on it, and again, even with no signal, the truck should still have spark/limp mode.
Sorry Dan, didn't mean to jack your thread.
It seems like you've pretty much eliminated all of our guesses. I would start checking grounds in your main harness. I forget, did you get a tune done?
BTW, I didn't know the ECU would switch over to the crank sensor if the cam synchronizer failed. That's useful info, thanks!
Forgot about Hoosier.
Truck of the month and a great write-up on your swap and he forgets about you?I get that a lot. Something about being a sleeper.![]()
