which york for oba on 4.0
tinys91
Nor-Cal foot hills Gold country
Has anyone done this on the RBV? Brackets that would make it possible to use the stock mounting position? Is there a particular model # that allows use of the stock pulley? Can these be made compatible with stock ac length belt? The tech. info is a little vague. dose anyone have some more specific info. I have searched some, but haven`t found much for RBV`s
My ac took a dump along time ago and I have the stock bracket sitting there waiting for me to do something like the york. When I built my truck I mounted a viaire compressor, it works but is so slooow its painful. Airing up at the end of the trail is 45 min. to get 35lbs. in my 37x12.5x15`s. I have seen a company that has complete kits for any jeep you can think of also Chev. and dodge, but nothing for ford.
If there was an emergency and I needed to get on the road it would not be good taking that long to get going once you get to pavement.
post pics!!!! i would love to see this work...
question is, would it run all the time, or would the clutch be hooked up to a pressure switch type deal? or would you just have the pump run when you needed air, and no tank?
Tiny, what is the specs on your rig? I like info. It's a 91 but what else? More info would get more results! :icon_thumby:
If you can't find a york that will work just pick up another stock compressor. I ran an oba system on my FSB for quite a while with a factory compressor. It is a little more work but you can put an inline oiler at the inlet and a seperator on the outlet. It worked well for me.
Sent from my SAMSUNG-SGH-I897 using Tapatalk
Tiny Ranger specs.
91 extended cab 4.0 auto 4x4
2001 explorer disc brake rear end
Dutchman hardened axles 5 on 5.5
Detroit locker 5.13 ring/pinion
97 extended cab one piece drive line, customized cross member, new exhaust
explorer rear springs re-arched 2"
4" blocks
3" body lift
8" skyjacker front coils setting on 2" SS spacers for a full 8"`s lift in front
modified supper runner steering with 3.5 drop pitman arm
steering knuckles off 85 full size bronco Dana 44
skyjacker extended radius arms
super 35 ARB 5.13 gears custom Dutchman hardened inner 31 spline axle
9500 lb. warn winch in home made mount & bumper
Viaire compressor plumbed to air tank from 18 wheeler mounted under the bed where the spare tire used to be,with air gauge and switch mounted in the dash and an air chuck plumbed inside the cab to air up from. compressor is wired through a pressure switch set at 120 lbs.
customized Superlift pivot brackets to get full 8" lift and be able to align properly
5" running lights on the bumper from napa
optima battery (blue)
pioneer super tuner alpine speakers front/rear (amp and a pair of 10" soon to come)
92 mustang seats stock console
37x12.5x15 TRXUS by Interco on old school American 5 hole aluminum rims
rear bumper air tank coming soon. I have the material just need to do it!!
I think thats it.
rear bumper airtank... please don't tell me that is what it sounds like...
you need to post pics in this thread
Huh...so you're running custom shafts on your TTB?
Nifty....I like it.
I started on a bracket to mount a York 210 on my 4.0L in my 91...never did get it finished or install it. I was going to run a V belt clutch on it (already have one) and then run a secondary V belt pulley off of my powersteering pump The bracket will mount to the top of the factory mount. The compressor will sit on its side.
As for using the stock style compressors.....they just don't last. The older style found on the 2.9L seem to last forever, but the 4.0L version just can't handle it. Works good for a while then eats itself up.
I had a piece of 1/4" plate broke into a u shape and got a piece of 1/4" x 6" flat to fill the opening. I am going to fit and weld it and make an air tank.
What are you thinking???
I am going to cope the ends in the shape of the stock bumper and mount it like stock. the stock bumper is 6"x6" if it was a tube.
http://www.onboardair.com/compressors.htm
"[FONT=Arial, Helvetica, sans-serif]When the York compressor is mounted on its side, the suction port has to be on top in order to function properly. Please take note on which side you plan on laying the compressor and order accordingly."[/FONT]
