its a passenger side pumpkin.but all i would have to do is get a rr r&p so i can flip the axle right?
also does anyone make rotors with a 5 x 4.5 bolt pattern for the 8in
i was told i can get a drop out from a 8in rev axle and it will work.im not going to be using a gearbox so i don't care to move the knuckles.its use will be mainly for sand and steep hill climbs,not rock crawling were i have a chance to snag a knuckles.yea i was luck to get it but the clean up wasn't a small chore took a lot of gas running back and forth to a dump and metal recycling place.and the axle only has 75000 miles on it.
I think you need to think through what you're wanting to do here a bit more (and get a more reliable source for your info as well).
If you flip the housing without turning the knuckles back over, your steering inclination angle would be totally bass-ackwards (and who knows if the kingpin bearings would tolerate being loaded from the wrong side). Not gonna work, although if you still want to check it out for yourself, that's fine with me.
im puttin on into a projvect bII i got, already got the front all fabbed up......and im running chebbie drivetrain....becuase making the yota solid front will not function as a drivers side drop in any way shape or form...if it could be done cost effectivly then everyone who wanted todo a SAS would already have been on its nuts...
not knocking you for wnating todo it, just saying your biting off more then u can chew
