First thing is, Is your 302 a roller engine or not? If its a roller you need to use a distributor with a steel gear and if its a flat tappet cam you will need to use a dizzy with a cast gear. For a roller cam use the dizzy for a 85 Mustang GT with a Holley 4 barrel carb and for a flat tappet cam use one for a 84 Mustang GT. The easy way to wire it up with the least connections is to find a stock Ford duraspark box and harness as you will only to make two connections and the reast is just plug and play. There is no advantage to using a GM module and it is more a pain to use anyways. You will need to make a heatsink for it and mount it some where and then make up your own wires and if it dies then you are stuck unless you have tools to replace it right there. The Ford Duraspark is a much better deal as if it dies you just unplug the dead one and plug in a good one and go untill you find some tools to do it right. The other big advantage is the Ford duraspark box retards the timing while you are cranking the engine to make it start easier and it also saves the starter doing that. More pluses to the Ford stuff then the GM junk.....
