Ok so if you cut and turn your beams you get 4 inches of lift in the front....
I want to do the 64 inch leaf swap with a 12 inch arc in the rear with the 7 inch shackle and flipped mount, which leaves me with no lift according to the tech library.
Do prerunners sit lower in the back by 4 inches? or do they make custom brackets to not only flip the shackle mount but drop it down 4, 3, or 2 inches causing a lift?
Also, at what percent of the full suspention stroke should the truck sit at on level ground? Meaning % Compressed? front and back...
Im really trying to learn alot befor i dig into my truck... i think its best for the wallet that way, ill be less likely to make costly design mistakes or order the wrong parts....
Thanks Guys!
Thanks Guys!
