Snorkle for the ranger
suzuki14258
Yeah, I think that's the one a few have used. Looks pretty good mounted up.
Ya it looks clean on the ones i saw, i will probly mount mine upside down are something with my luck lol. I do have one question for those that have used this set up, after you make the template and drill the large hole in the fender what holds it in place, do you have to take the fender off to bolt/screw it down? ( i know i will have to take the fender off to run the tubing)
This is just my assumption:
The piece that is sticking through your fender is either threaded, barbed, or just smooth. If it is threaded then whatever threads onto it should hold it on. If it is barbed or smooth you would slide your hose over it and clamp it in place. and the larger diameter of the hose clamped in place would hold it secure.
Like I said, That would be the most logical to me. But I may be way off.
Do a search on it. This was posted not long ago. One of our guys here has done it. He also might reply. I forgot who it is. Getting old....lol
I've done it twice now, used a Safari Snorkel for an 80's land criuser. Search my "Rangebe" builds, you'll see exactly how I did it. There are 4 studs that come on the back of the snorkel, that you bolt from the inside of the fender. You do not need to remove the fender.
Awesome! Just one question how do you search builds?
Nevermind i think i figured it out....
