- Sep 14, 2009
- SE Michigan
Our ranger just stalled out while driving, I suspected the alternator and repair shop comfirmed. I would have replaced it myself but we did not have the time and were left stranded.
Anyway the truck always started fine no problems but the problem occurred out of the blue yesterday, when the engine started sputtering while on the road, radio intermittently went on and off, engine sputtered to a stall.
Shop replaced the alternator and they said we also needed a new battery but I think the battery is OK because it always started up fine no problems. However mechanic said the bad battery can burn out the new alternator if we don't replace it ASAP, so if needed I will buy new battery and put it in myself.
So we are going to pick up the truck today, if the truck starts up AOK, does this mean the battery is OK? Or is there a simple kind of test I can do to check the battery?
I was wondering if maybe the internal resistance of the battery is high and causing the alternator to over work or something like that? Or maybe it's a short to ground somewhere?
Thanks for any info or suggestions.
