alrighty , most of you that have been here a while and know me remember my Fully Loaded 97 Ext Cab that i bounced off a tree and then blew the engine up , well after a full year of letting the truck sit the time has come to rebuild it. And this is more than a rebuild , this is a full Rebirth , the truck is being completely torn down and rebuilt to some extent from the ground up , and here is the plan for it
1. Replace Bed
2. have spray on bedliner installed
3. 32 Inch tires
4. 2 inch spidertrax wheel spacers
5. make brackets for lights on roll bar
6. install lights on roll bar
7. have frame sandblasted/needle scaled and painted
8. replace core support
9. replace fenders
10. replace headlight panel
11. replace lights
12. install switch panel on radio
13. install locker in front diff
14. make front and rear bumpers
15. new front brakes/bearings/seals
16. new clutch master/slave cylinder
17. 200 amp powermaster alternator
18. fix A/C system
19. turn old bed into matching trailer
20. get painted
21. moonvisor
22. 2000 one piece driveshaft conversion
23. install fender flares
24. swing out rear tire carrier
25. hi lift on roll bar
26. 8k pound winch on front bumper
27. rock sliders
28. 4.10’s in both axles
29. 1.5 inch Blocks
30. 1 inch coil spacer in front
31. Sway Bar delete
and soon i will post pics of the progress thus far , it has started to really get going the past couple days
1. Replace Bed
3. 32 Inch tires
9. replace fenders
11. replace lights
18. fix A/C system
20. get painted
21. moonvisor
27. rock sliders
29. 1.5 inch Blocks
31. Sway Bar delete
