rant. electric fan vs clutch fan
bubbafinch07
10+ Year Member
quincy fl
1990
200
Hi all. I'm just alittle tired of hearing other people tell me that clutch fans are better and more efficient than electric fans. On nearly every application I have seen the clutch fan puts way more drag on a belt drive that when a electric fan is turning on even at low speeds.
To prove this I took my stock ranger (2001 4.0 2wd) auto. First I drove it on the interstate cruise set at 70 mph and averaged 18.1 mpg over about 100 mile trip. Also took it to my local 1/8 track and ran a best e.t. of 10.64. The next weekend I changed to a electric fan I had laying around that came off of a ford escape, it is a two speed electric fan that I ran off of a toggle switch three position so I could use both speeds. I went and ran the same 100 mile trip at about the same temp off by less that 5 degrees and little to no wind. I averaged 18.9 mpg, so not a big difference. However when I took it back to the track I ran 10.10 at the same track. And the track condition where again identical and I had the same amount of fuel within a gallon or so. So as far as I am concerned electric fans are more efficient and take a significant amount of drag off of the belt drive. But to each his own I guess. Rant over.
I'm going to agree with you. I've had an electric fan on mine for a few years now. NOT one complaint.
I'm in Texas and we are in the middle of a brutal heat wave. With 100-plus temps and the AC working overtime, the engine temp stays right on the money.
Most people who complain about electric fans don't even have one.
I didn't know there was a big fight going on. My opinion is, electric fans are fine on passenger cars and light trucks. On a medium or heavy truck, you can hear the fan clutch engage with a huge squeak-jerk and then it blows like mad. That would be an expensive and heavy electric fan motor.
i like my clutch fan. it came on the truck and i dont care enough or have the money to go electric.
people always whine whenever some one says they are going to put an E-fan on they're ranger, but i just realized the other day that my stock clutch is broke so my fan never locks in and the truck keeps getting hot. So my 2.9 will have an E-fan fan soon! What size fan are you running, i have a 10" and thinking about getting second 10" if it will fit. its on my to do list
I have a 16" 2500CFM flexalite pusher on a two core exploder radiator, kept my 302 cool running around town today. Indoor/outdoor thermometer read 98 degrees when I left work with 80% humidity. Heck at 10pm we still had a 110 heat index. When it kicks on it sounds sorta like a Kenne Belle, otherwise I can't tell powerwise it is running.
That said if I had the room I would happily run a mechanical fan. Much less to go wrong, a pinched or mouse chewed wire and I am screwed.
Me either.
In my experience, electric fans work great if they were designed for your vehicle. They really need a shroud that pulls from the entire surface of the radiator to work properly.
Really though, it's a matter of opinion, and also a case by case basis as to how your vehicle responds. Installation, CFM, Thermostat, wiring, condition of your cooling system, etc. all make or break the deal. I don't need to worry about most of that garbage with a clutch fan, it just works.
Which is why the Taurus fans work so well, they fit our rads damn near perfectly.
