Went to the barn
jammert609@yahoo.com
10+ Year Member
Backwoods NC
Parked the ranger today in hopefully to fix the 2.8 an afue other problems an run it untill the wheels fall off. looking forward to rebuilding my first engine, I am mainly focused on the carb,valve cover gaskets,netrual safety an the starter then I am going to fix the front end an get things right... I dont wanna get rid of my first truck so i am going to make it better.
yep..........take care of that old iron.......
you have a pull-a-part near you, just go buy a new 2.8.....v6's are cheap there
I rebuilt my 4.0 for under 500. Its not to hard. Pull the engine and take your time pulling everything apart clean everything paint your block get a master gasket set relapse your valves get all new seals get a clutch/pressure plated kit and mabey even buy a new carb If yours is acting up. Also be sure to buy lots of oven cleaner that stuff is the best thing to clean parts with. I sprayed everything wiht it and it melts grease off of parts I highly recomend you use it on your engine and your engine bay.
I've got an '86 2.9 in NE Ga. if you're interested.
A gasket set and a coat of paint isn't a rebuilt engine.
