Explorin94
Law Enforcement
EMT / Paramedic
Firefighter
- Aug 7, 2007
- Age
- 53
- Farmington Il.
I answered the question in post #5. The problem came about later. I'm not out to prove anything to anyone. I think we've moved off track a bit here. By pop-off valve I take you mean the high pressure release valve. It shouldn't go off at all if everything is working right. When it does go off, it usually means there's too much pressure in a more or less properly charged system caused by excess heat. 9 times out of 10 it's because the fan isn't doing it's job, crud on/in the condenser, etc., but I digress. It isn't there to let you know that you've overcharged the system. By the time you've charged to the point where the valve releases, you are already way overcharged, especially if it releases during an engine off or compressor off type charging. A proper set of gauges used while charging will prevent you from ever reaching that point. I don't mean the ones the the auto parts store sells that only measure the low side. I try to discourage people from using what I feel are unsafe practices.
There ya go....well said. I see you changed your other answer to this. Yes I was reffering to the high pressure release valve when I said pop-off valve. They more or less do the same job.
Like I said some of the guys...or gals here like to attempt jobs on their own. Even though there is the possibility they can get hurt (and with some of these jobs they can get hurt very bad) but, that is where we step in and tell them the dangers of it. Like the above post you had....you explain what needs to be done and how they need to do it. Let them determine if they need to take it in.
