I like the 302 decals. classy, not flashy.
Sigged.
Thanks Rico!!
Sigged.
EDIT: Found specs @ http://www.1993cobra.com/data.htm
Camshaft:
Ford designed a new camshaft grind to bring back some of the low end torque that was now lost using these higher flowing cylinder heads. Part number for the cam is F3ZE-6250-CA. Specs are as follows:
Intake/Exhaust duration in degrees of crankshaft rotation: 270/270 and at 0.050 lift 209/209
Intake/Exhaust lift at valve with 1.7 rocker ratio: 0.479/0.479"
Lobe separation is 118.3 degrees with 115 intake lobe center and a 121.5 exhaust lobe center.
Timing events at 0.050 lift are:
Intake: (BTDC):-10.5 / (ABDC): 39.5
Exhaust: (BBDC): 46.0 / (ATDC): -17.0
Here are the specs for all the cams to see what the differences are.
EDIT: I just realized that the B and E cam specs are for 1.6 rockers
EDIT X2: 600th Post!
yo shane, i was at my engine builders garage today and my engine is done!! it looks soo good. ill have to get some pics of it when i bring it home
whats up shane? not much here ya know, just here sitting with my PERFECTLY FUNCTIONING SUPERSTANG!!!!!!!!!! going to motor vehicle registration tomorrow and getther her licensed!
aww man i'm kind of upset you ditched the gt lights, and did you ever decide on what to do wheel wise.
Hey bud, I'm sorry I've havn't been checking out your build thread. You got your self a damn nice build going. Heres a link I found for wheels:
http://www.cruizinconcepts.com/4lugwheelsrims.asp
If you ever plan on doing a five lug conversion the FR500 wheels would be badass. One of my all time favorite wheels.
