- Jan 15, 2011
P R O B L E M........S O L V E D.....---.....C L O S E........T H R E A D
I'm sorry for the length of this but I hope the info helps. Thanks for help.
I have an 88 ranger 2.9l, 5 speed, manual tcase, 235/70r15 with stock gears. I notice that it is missing some because I can feel when it fires on all 6. Even driving down hill in 5th gear, tach @ 2400 I LOOSE SPEED. I can not maintain 65mph down hill, let only uphill I slow down to 3rd gear 3500rpm and 46mph.
I know it is not gas quality. I am blowing black smoke bad. Running to rich. Sometimes it will only run on 4 cylinders. I changed the cap/rotor, wires, coil all with no change. Uphill/downhill or flat ground it might run on 6 cylinders, 5 or 4. The GPS shows I am averging 41 on the express way. How do I know if the FPR or TPS are working correctly?
The vacuum line from the FPR to vacuum port is dry. It does smell like gas. Some one local suggested either the ACT or MAP. I know the MAP should test out to 156MHZ but I do not have a tester to check MHZ. What are some of the symtems of a bad MAP or bad ACT?
I hooked a fuel pressure gauge to the schrader valve on the fuel rail. Turn the key on, not start, holds 30-32psi. I know the haynes says 40. It will run fine at that pressure on 6 or 5 cylinders but when it really starts to cough and bog down the pressure RISES to 40-42. When it settles out and runs correctly it is back down to 30-32psi. I have now changed the ACT sensor and the MAP. Both of these helped alot but it still does not run properly. It will run longer on 6 cylinders now, but every 2-5 minutes it will still drop one or two cylinders then go back to 6. It does not run good enough that I would feel comfortable driving back to MI from SC.
So far I have replaced the ACT,MAP, cap, rotor, wires, plugs, cleaned the iac and TB.
I think either a bad signal to the injectors or clogged injector. I have looked at the wiring diagram in the tech section and see that 361/r goes to all the injectors and 3 have LG/W and 3 have T/R. ???? Which wires would be getting the bad signal -- the common red to all OR the others??? Did I see on this site a place to rebuild the injector?? If so, I do not remember under which forum.
