- Dec 11, 2008
- Southern Illinois
I have searched and haven't been able to find really any answers to a few questions.
Has anyone used, or knows if parts from a 1991 F150 would fit for a swap.
Main parts of concern are...
Exhaust manifolds
Front accessory Drive (A/C, Power Steering, waterpump, alternator)
The donor is a 1991 Ford F150, 302, 2wd, a/c.
My vehicle is a 1984 B2, 2.8, c5. I already have a rebuilt c4 to swap output shafts with the C5 and drop in to keep driveline lengths the same and motor mounts.
I am hoping to be able to keep the radiator in the stock position without moving it forward and tucking it up under the support, keeping the air conditioning system operational, convert to the serpentine belts off the truck, and delete the smog air pump.
I think I can come up with a shorter belt and just leave the air pump off and bypass where the pulley would have been.
I also have access to a shop that can make the a/c lines up to match the stock B2 fittings to the newer a/c compressor.
I am just trying to get a little information before I pull all the parts off the truck and start pulling my engine out of the bronco. Any insights would prove very helpful.
Thanks.
Exhaust manifolds
Thanks.
) The axle closed the elbow by half. Others have used them and claimed to have success, but after the experience I had with em, I swore off em and looked for another solution. I tried a used set of Hooker swap headers (that may not have been, coming from an ebay buy) then modded a pass side 65-66 Stang 351W swap header, then went to Shelby Tri-Y's.
