- Feb 25, 2011
- Age
- 42
its the transfer case control module, i had the same problem. you can run a self test on the module ( located behind the drivers door in the side panel) turn key to the on position and push the button on the right side of the module. it should flash once every second, if so its good to go. if it stays lit or doesnt light at all, theres a malfunction. you can dig one out of a B2, an explorer up to 94 or a ranger from of the same years. i got one for like $11 at pinknpull.
in explorers its in the trunk on the left side. I cant remember where they are on rangers, hope this helps
It should be a lil red light too right?
