- Aug 17, 2007
- central ohio
- 2.5 (4 Cylinder)
- Tire Size
- 235/70/16
- My credo
- the grey-t escape
no frills, no extras, hell-no throttle cable even. this was my grandma's way back in the day, been in the barn for over 17 years with a bent blade. my self-propelled snapper had been very low on compression and had carberator issues, i took off the carb from this one, put it on the snapper along with a new head gasket and its been back in service. i decided the old push mower wasnt in bad enough shape to warrant being discarded, cleaned the deck up, found a "j.c. penny" sticker on the back. fixed a few cracks on the deck where the engine mounts, reinforced underneath with some channel iron, gave the motor a magnatron coil to replace the points ignition and a new lower crank seal. then it was time for paint. being a farm kid, i just had to go with a tractor theme, not deere this time, been done, i went to the idea of the post-jubille ford. blue with white trim, why not, a ford push mower. i still need wheels and a different blade, the blade i put on took a adaptor which lowered the blade almost 3 inches, with the deck all the way up theres only 1" between the blade & the ground, and the blade is completely below the bottom of the deck, debris goes in all directions to say its unsafe is a understatement. ran it on pavement and it runs nice, will idle down and doesnt smoke, has a external breather which i routed to the discharge side of the deck. all in all ive put about as much in it as you could buy a new cheapie from wal-mart (125) but this is better, no plastic carb, no deck flexing, no damn "hold the bar or it stops". the snapper is down now, got a carb diaprahm but it just doesnt want to stay running. guess i'll deal with it next. took alot of sanding and looking with the right light to find the numbers on the motor shroud, but i found them, turns out the engine was built in '74. hard to say what color the deck was originally, i found black paint, green paint, red paint. dont really want to remove the label, kind of adds to the "vintage" of it. may take this and the 110 ive redone to a few ag shows. might put the F-O-R-D letters across the front of the deck, and a blue oval emblem for the recoil cover (or the thunderbolt with gear)
