- Jan 16, 2008
Hey guys.. Ive been through the worst clutch change in history here..
very long story short, ive broken the high pressured cable going from my clutch master cyl to the internal slave in my 1992 2.3L 2wd (mazda 5speed).
ive managed to hacksaw off the end of the cable going into the "quick release" and removed the whole slave cylinder and release bearing. The quick release tip is still attached to the slave cylinder as i cannot figure out how to remove it. I would very much like to replace the extremely brittle and stiff clutch cable i just broke with something flexible like a braided metal cable if possible.. also I'd like to be able to connect and disconnect it from the internal slave WITHOUT having to remove the tranny.. Ive got the correct tool for easy disconnects with the oem disconnect.. but it just didnt work.. it was jammed up good..
Anyways I'm going to need to know...
1 how to disconnect the quick release fitting from the internal slave cyl
2 where a good place to buy a suitable aftermarket cable (ford will be expensive)
3 how to disconnect the master cyl from the broken cable.. im assuming its the same connection
attached is a picture of my internal slave and the fitting which seems to be outsmarting me
4 how to remove the release bearing from the ISC as in picture.. ive pushed pulled and twisted every way i can think of and cannot get it off to replace with the new one sitting also in picture.
the valve looks like it has a tiny little pin i could probably hammer a mini allen key through to remove pin... assuming after that it would come free, but i wanted to ask before i broke anything else.... first clutch change here..
