- Aug 6, 2003
just an update.. got the truck back together in one piece... however i pulled the master and cable out of my other truck.. other truck has a 2.9 and is 1990, mine is 2.3 and 1992... everythign looks identical as far as the master cyl goes.. but i cant get it to stay hooked up to the clutch pedal..
one push down and the plunger pops off.. sooo frustrating![]()
i dont know what i could have done wrong here, that tiny little plastic bushing that fits into the hole on the clutch plunger side pops right on, far as i can tell its not broken. ford quoted me $20 just for a new one, and now they're closed so i cant really do any more tonight unless i missed something obvious.
You're missing the clip that holds the plunger on. If you look on the little "knob" that the plunger hooks onto, it's grooved towards the end. That's where the clip goes.
After I lost the clip for mine and didn't have one in the shop that was the same size, I used a small piece of stiff wire and twisted it around where the clip was supposed to be. It was tight enough to work safely after I twisted it with a pair of pliers.
