Getting new/used tires for ranger
jammert609@yahoo.com
10+ Year Member
Backwoods NC
I got ahold of a set of used set of tires to go on my truck an i was wondering if they will fit in my wheel well with no problem, the tire size is 225/70/14, will these fit under my truck w/o a lift.i got the set for 150.00 bucks would yall say its worth it. I was told it would be a tight squeeze I was told they came off a ranger but they look like 4x4 wheels thall fit on my stock rims.:headbang:
depends on what condition for 150. tire place here will sell you used tires mounted and balanced for $35 a piece.
that's the stock size that came on my 94 Ranger
theyre new dont have many miles on them, will they fit under my truck
Which is it? Are they new, or do they not have many miles on them?
Just busting your balls. :thefinger:
I ran 235/75r15s on the back of my 2wd 1st gen for a while. They're bigger and didnt rub. I would say you have a good chance of them fitting, but every truck is a little different.
I have 30x9.5xR15's on my truck. They're stuffed but I think they work just fine.
the wheels
  • Getting new/used tires for ranger
I have P225/75/R15's on my ranger and they fit fine in the back, but the front is tight and I had to cut the inside of my fenders a bit to keep them from rubbing when going over bumps.
