2.2l diesel question
6.9l ford
Ok, is for the ones with a 2.2 mazda/perkins that have gone a put a turbo on it. What psi is your boost? Did you replace the stock exhaust valves with a heavier duty version for the high heat that the turbo will make. What is your EGT? I am almost ready to do the gas to diesel swap on my '94. I know that someone will say I need the 2.3 diesel but, I got a sweet deal on the 2.2 so I'll be using it, and modifing it. :icon_hornsup::icon_welder:
Wish I could find a 2.2 or 2.3, seeing how the price of fuel is. I have heard of guys able to get 40mpg from a 2.2.
Ya, 40 would be nice! Hopefully that is true. Mine has the rare 5 speed too.:icon_hornsup:
I helped a guy out that did it. He got a turbo from an 84 Dodge minivan. I built an adapter for the turbo to manifold and an oiling/return line setup. The stock setup put out 20 lbs. First it blew the original manifold gasket, we changed that to a homebuilt steel one, then it stretched the headbolts and blew the headgasket.
We fixed all that with stock parts and I built an adjustable wastegate. We set it at 12 lbs max. and its been fine for 2 years and 25,000 miles.
The '83 2WD Ranger had 95,000 miles when we started. The engine was never apart before. About 5,000 miles after we got everything working right, the owner wanted to switch the 4 spd to an auto. When he did, we pulled the engine oilpan to check the bearings. The main between 2-3 had quite a bit more wear than the others.
Just a theory, but we figure he might have caused this by too much boost at the beginning. We checked the linebore and the crank, both were dead on, so.....?
He gets 35-38 mpg (Canadian) = 30-33 mpg US. He has power in the range between a stock 2.3 gas and 2.9 gas. Not a screamer, but no slouch.
He gained about 8 mpg with the turbo, but lost about 3 to the auto. With your 5 spd you really should see close to 40.
So between a 2.3 and 2.9 is the 2.8, which is rated at 115hp, thats a huge gain from the 59 from the factory.
the compression ratio of the 2.2 is 22 to 1. I know with other diesels in that range 8psi is about max in stock from.(12psi with head studs & mls headgaskets) So a Warner-Ishi from a 2.3 gas engine with about 8 psi should be about right, but I hear that the exhaust valves can be badly burned with the addition of the turbo.:bawling:
But the swap will happen with or without a turbo.:icon_hornsup::icon_welder:
I will say anything to help give the little engine a bit more power would be good.
does anybody have for sale, or have a line on a oil pan for the 2.2 perkins/mazda in a 1983-1984 ranger?? thanks Jason
I say try ebay or google it, thats what I do when I need to find something.
