- Nov 27, 2009
94 Ranger 4wd, 4.0l, auto. I think it has some type of posi as I cant spinwhen one wheel is jacked up, and when both are off ground both spin same direction.
Problem is that my son seems to be eating up the rear tires. He's not an idiot doing burn outs, thank you.
Opinion as to what to do, is this normal? Would a fluid change with proper friction modifyer help/fix? Or does the posi/ls need rebuild?
Only non stock item is when he bought some used BFGs on Grand Cherokee rims he only swapped the fronts and used the jeeps on rear. Would the little bit difference in wheel offset cause this?
Let me know if any other info is needed.
Thank you for your help !!
BTW, I did search tire wear in this forum and didn't find anything relevent.
