Fuel:
Miles Per Gallon Calculator
Speedometer:
Check Speedometer After Tire Change
Speed From Gear Change
Combined Tire & Speed Calculator
Speed Calculator
Axle & Gears:
Gears Needed After Tire Change
Ring And Pinion Calculator
Determine Final Crawl Ratio
Tires:
Convert Metric Tire Sizes To Inches
Suspension:
Coil Spring Rate Calculator
Leaf Spring Rate Calculator
RTI Ramp Calculator
Converters:
Converting Fractions To Decimals
Distance And Length Converter
Capacity And Volume Converter
Weight And Mass Converter
Currency Converter
Bolts:
SAE Bolt Torque Specifications
Website |  + posts
Jim Oaks is the founder of TheRangerStation.com, the longest-running Ford Ranger resource online since 1999. With over 25 years of hands-on experience building and modifying Ford Rangers — including magazine-featured builds like Project Transformer — Jim has become one of the most trusted authorities in the Ford off-road and enthusiast space. In 2019, he was loaned a Ranger FX4 by Ford Motor Company to test and document across the TransAmerica Trail. Jim continues to inspire and guide Ranger owners around the world.
