| Home | Forums | Tech Library | Magazine | Video Gallery | Truck Gallery | Shirts & Decals | TRS Fab & Off-Road |
Winch Performance Guide |
| First Layer Pull/Speed/Current (12V) | Pull By Layer | Dimension | Mounting | Warranty | ||||||||||||||||||||
| Low Range Winches | 0 | 1.5K | 3K | 4.5K | Full | 1 | 2 | 3 | 4 | 5 | ||||||||||||||
T-MAX EW-6500 |
f/m Amps |
6500 |
5400 | 4620 | 4000 | 3580 |
18.5"x6.3"x8.1" |
10.0"x4.5" |
Limited
1-year |
Warn M6000 |
f/m Amps |
6000 |
5460 | 5000 | 4670 | na |
21.04"x6.3"x7.6" |
10.0"x4.5" |
WARN Limited Lifetime |
M. Marker PE 6000 |
f/m Amps |
6000 |
5000 | 4250 | 3720 | 3300 |
17.25"x6.22"x7.28" |
6.53"x4.5" |
Limited 2-year |
S/W X6CD |
f/m
Amps |
na |
na | na | na | na |
22.88"x6.75"x6.63" |
10.0"x4.5" |
1 -year |
Ramsey Proffile 6000 |
f/m Amps |
6000 |
5075 | 4400 | 3880 | na |
22.65"x6.62"x6.10" |
10.0"x4.5" |
Limited Lifetime |
| Mid Range Winches | 0 | 2K | 4K | 6K | Full | 1 | 2 | 3 | 4 | 5 | ||||||||||||||
| T-MAX EW-9000 | f/m Amps | 37.2 70 |
13.1 260 |
7.2 425 | 9000 | 7990 | 7237 | 6713 | na | 22.0"x6.3"x8.1" | 10.0"x4.5" | Limited 1-year | ||||||||||
| Warn M8000 | f/m Amps |
16 200 | 11.9 285 | 9.79 350 | 8.01 435 | 8000 | 7280 | 6670 | 6230 | na | 21.04"x6.3"x7.6" | 10.0"x4.5" | WARN Limited Lifetime | ||||||||||
| Chicago Tools 8000 (H.F.) | f/m Amps |
11 | - | 6 | 4.5 | na | na | na | na | na | 20.69"x3.13"x6.94" | 10.0"x4.5" | na | ||||||||||
| M. Marker PE 8000 | f/m Amps |
11 100 | - | 6 230 | 5 300 | 8000 | 6335 | 5243 | 4473 | 3900 | 22"x6.22"x7.28" | 10.0"x4.5" | Limited 2-year | ||||||||||
| Ramsey Profile 8000 | f/m Amps |
18 210 |
8000 | 6550 | 5540 | 4800 | na | 22.65"x6.62"x6.10" | 10.0"x4.5" | Limited Lifetime | ||||||||||
| Mid-Hi Range Winches | 0 | 2K | 4K | 8K | Full | 1 | 2 | 3 | 4 | 5 | ||||||||||||||
| T-MAX EW- 10000 | f/m Amps | 29.5 70 | 14.4 170 | 11.9 240 | 8.7 380 | 7.2 425 | 10000 | 8633 | 7716 | 7089 | na | 21.15"x6.3"x8.6" | 10.0"x4.5" | Limited 1-year | ||||||||||
| Warn XD9000 | f/m Amps |
14.4 180 |
6.88 415 | 6.38 460 | 9000 | 8190 | 7500 | 7010 | na | 21.8"x6.3"x7.6" | 10.0"x4.5" | WARN Limited Lifetime | ||||||||||
| Warn 9.5xp | f/m Amps |
12.8 262 |
7.6 480 | 9500 | 8650 | 7920 | 7400 | 6940 | 22.7"x6.3"x7.7" | 10.0"x4.5" | WARN Limited Lifetime | ||||||||||
| S/WX9 | f/m Amps |
13.8 165 |
9 240 |
- | 2.5 420 | na | na | na | na | na | 22.88"x 6.75"x6.63" | 10.0"x4.5" | 1 -year | ||||||||||
| M. Marker SE 9500 | f/m Amps |
13 160 | 10 180 | 6.5 350 | 5 380 | 9500 | 7500 | 6200 | 5300 | na | 22.0"x6.5"x7.3" | 10.0"x4.5" | Limited 2-year | ||||||||||
| Tabor 9K | f/m Amps | - | - | - | - | - | na | na | na | na | na | na | 10.0"x4.5" | Limited 1-year | ||||||||||
| Ramsey REP 9000 | f/m Amps | 33 97 | 16.7 180 | 12.7 260 | - |
9000 | 7300 | 6200 | 5400 | na | 22.65"x6.12"x6.38" | 10.0"x4.5" | Limited Lifetime | ||||||||||
| Ramsey Profile 9500 | f/m Amps | 35.4 97 | 16.7 180 | 12.7 260 |
7.8 430 | 9500 | 7780 | 6600 | 5725 | 5050 | 22.65"x6.62"x6.10" | 10.0"x4.5" | Limited Lifetime | ||||||||||
| Chicago Tools 9000 (H.F.) | f/m Amps | na | na | na | na | na | 20.69"x3.13"x6.94" | 10.0"x4.5" | na | |||||||||||||||
| T-MAX EW-1 2,500 | f/m Amps | 23.5 70 | 12.6 125 | 10.3 165 | 7.2 275 | 4.3 415 | 12500 | 9210 | 8030 | 6894 | na | 21.3"x6.3"x8.6" | 10.0"x4.5" | Limited 1-year | ||||||||||
| Tabor 12K | f/m Amps | na | na | na | na | na | na | 10.0"x4.5" | Limited 1-year | |||||||||||||||
| Warn Ml 2000 | f/m Amps | 30 67 | 14 140 | 8.6 210 | 5.8 320 | 3.86 440 | 12000 | 11120 | 10340 | 9770 | 9250 | 24.37"x8.45"x11" | 10.0"x4.5" | WARN Limited Lifetime | ||||||||||
| M. Marker SE 12000 | f/m Amps | 15 96 |
5.2 350 | 12000 | 9600 | 8000 | 7000 | na | 22.1"x6.5"x7.3" | 10.0"x4.5" | Limited 2-year | ||||||||||||
The specs noted here may not be accurate nor current. The latest and most accurate information should be sourced from manufacturer websites.
