stieny
I was having a few issues with my Ranger and I was hoping a few more people could give their two cents about it. I'll try to make it as short as possible....
So my '94 Ranger has about 96K on it now. A year or so ago I was running it out to Philly for work. I live in Pittsburgh. I was trying to push it to my exit and ended up running out of gas. After I got through that mess and was coming home a week later it was running terrible and throwing lean codes. It was hesitating real bad and missing. I got home, changed a clogged fuel filter, cleared codes, and all was good.
Fast Forward to this past weekend. I take a trip up to NYC. Again, I live in Pittsburgh. Running for about 4-5 hours and filled up a few different places. I am about an hour from where I need to be with a little over a quarter tank and it starts hesitating very similar to my Philly trip but no where near as bad. (Granted, over the past year, I have been known to run down my fuel pretty low before refilling) It would be hesitating in 5th gear, downshift to forth, give it gas and it would hesitate a few times and then smooth out and start accelerating. And it did it the same way every time. And it was throwing CEL's left and right. But the CEL and hesitating were sporadic and not always simultaneous.
So I stop at a parts store and change the fuel filter in their parking lot. On the way home, It started doing the same thing to a T. Didn't seem to matter if the tank was full or empty.
Now home, I changed the plugs, wires, cap, rotor, air filter, oil and filter, IAC's clean. I pulled the codes and they read:
175 - (M) Oxygen sensor not switching - system was at adaptive limits - Left or Front HO2S - Fuel control
176 - (M) Oxygen sensor not switching - system is or was lean Left or Front HO2S - Fuel control
542 - (O,M) Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits
543 - (O) Fuel pump monitor circuit shows no power - Power / Fuel Pump Circuits
Codes are cleared and it's not throwing anything but it doesn't seem to be running with a lot of power and seems like it still has a small miss every now and then. I'm leaning towards just an over-worked and tired pump. I have a new pump and am going to throw it in once I burn through this tank of gas. I could read the pressure at the rails but just haven't done this yet.
Just wondering what you guys thought. Thanks for reading.
