mountainkowboy
- Dec 15, 2007
- Age
- 67
- Socal Desert
- My credo
- Sucks to be you
So really, how bad is this tranny? Are there any issues that I need to be aware of?
Installing a Torque Converter lock up switch.
The lock up TC circuit is a ground switching system. The ECU grounds
the circuit to control the operation of the TC. So in order to install a
switch to force lockup all you have to do is hook up a grounding circuit.
Locate pin #53 on the ECU. They are numbered on the ECU.
Tapp into the pin #53 wire in the engine management harness.
Run a wire from the pin #53 wire to a switch, then from the other side of the
switch to a good ground. I ran mine to the negative battery terminal.
Note: Haynes manual says the wire is Pink and Yellow but mine is Orange. You can
verify the wire color by looking at the TC plug on the transmission.
Now you can control lock up. When the switch is in the on position the lock will stay
locked up regardless of engine load as long as the transmission is in 3rd or OD.
When the switch is in the off position the lock up will operated as it always did.
Note: There is no lock up in first or second. The valve body overrides it in
those ranges. Also remember to turn the switch off when comming to a stop or the
engine will lug down until the transmission drops out of 3rd gear.
your options would be either a 4R55E or a 5R55E auto tranny from 95 and up RBVs.
http://www.therangerstation.com/tech_library/AllanD_transguide.htm
I don't think the 4r or 5r will work behind a 2.9lt. They are electronicaly controlled tranny's and would need the engine and ecm that came with the tranny.
Derek
Sure they do. Just have to swap the internals from the 5R55E into the A4LD case al-a Franken-tranny !!
