jhammel85
Guest
Hey Everyone,
Well...I had a hell of a time today working on my truck. I went to replace the O2 sensor and it was completely frozen in place. I tried heating it, using leverage and nothing worked. I actually bent 2 breaker bars trying to get it loose. They are craftsman so at least I can get replacements.
on the 3rd, it completely stripped the bolt when it got loose from me. So now, its almost completely round.....I broke the top off so I could use anything I want after it gave me a lot of crap so I can still work with it. I think...But what would you all recommend? There isnt much space at all under there, plus the angle doesnt help.
There isnt a way to drill it out or anything like you would normally do when something is stripped.. I was going to pull the Y pipe down and get this part out the right way (at this point) but I'm really scared about breaking the bolts loose at the Exhaust Manifold flanges. If they snap, then I'd have to take the exhaust manifolds off... Anyone have any ideas for removing those bolts? Something you've done that would help?
The only other thing I can think of is I may pick up a bung for the 02 sensor and basically relocate the sensor right next to it. The wires are plenty long enough to do this. It'll be right next to it just maybe on the other side of the pipe because it'd be much easier to weld that way. It'll still be in that little bridge....Do you think it would throw off the computer?
Bottom line is...I'd like to get this thing out before anything. Any ideas on getting it out of the bung at this point???
